configure inline-power operator-limit
ports
configure inline-power operator-limit [milliwatts | class-based] ports [all |port_list]
Description
Sets the power limit allowed for PDs connected to the specified ports.
Syntax Description
milliwatts
An integer specifying the maximum allowed power in milliwatts.
Default is based on the port's class type (for example, 30W, 60W,
90W). |
| class-based |
Specifies that the power limit is managed by the
powered device's class. |
port_list
Specifies one or more ports or slots and
ports. |
Default
PoE—15,400 mW.
PoE+—30,000 mW.
PoE++ Type 3—60,000 mW.
PoE++ Type 4—90,000 mW.
Usage Guidelines
This command sets the power limit that a PD can draw on the specified
ports. For PoE, the range is 3,000 to 16800mW and the default value is 15,400 mW.
For PoE+, the range is 3,000 to 32,000 mW and the default value is 30,000 mW. For
PoE++ Type 3, the range is 3,000 mW to 64,000 mW and the default value is 60,000 mW.
For PoE++ Type 4, the range is 3,000 mW to 98,000 mW and the default value is 90,000
mW.
If the measured power for a specified port exceeds the port‘s operator limit, the
power is withdrawn from that port and the port moves into a fault state.
If you try to set an operator-limit outside the accepted range, the system returns
the following error message:
Error: Invalid operator-limit value. Must be in the range of 3000-90000 mW for PoE 802.3bt port
With a class-based operator-limit type, if a class4 PD is attached,
then the operator-limit set will be ignored and the switch will not deliver more
than 30W to the PD.
When class-based operator-limit is configured on a
port, "Max Allowed Power" will show the maximum power for the class of the attached
PD. Without the class-based option, "Max Allowed Power" will show
the configured or default value of operator-limit.
The following command sets the limit for legacy PDs on ports 3–6 of slot 5 on a
SummitStack to 10000 mW:
configure inline-power operator-limit 10000 ports 5:3-5:6
This command was first available in ExtremeXOS 11.1.
The class-based option was added in ExtremeXOS 32.3.
Platform Availability
This command is available on:
PoE+
- ExtremeSwitching
5420F-8W-16P-4XE—ExtremeXOS 31.3 and
later.
- ExtremeSwitching
5420F-24P-4XE—ExtremeXOS 31.3 and
later.
- ExtremeSwitching
5420F-16MW-32P-4XE—ExtremeXOS 31.3 and
later.
- ExtremeSwitching
5420F-16W-32P-4XE—ExtremeXOS 31.3 and
later.
- ExtremeSwitching
5420F-48P-4XE—ExtremeXOS 31.3 and
later.
- ExtremeSwitching
5420F-48P-4XL—ExtremeXOS 31.3 and
later.
- ExtremeSwitching
5420M-16MW-32P-4YE—ExtremeXOS 31.3 and
later.
- ExtremeSwitching
5320-48P-8XE—Switch Engine 31.6 and
later.
- ExtremeSwitching
5320-24P-8XE—Switch Engine 31.6 and
later.
- ExtremeSwitching
5320-16P-4XE—Switch Engine 31.7 and
later.
- ExtremeSwitching
5320-16P-4XE-DC—Switch Engine 31.7 and
later.
- 4220-12P-4X—Switch Engine 32.7.1 and
later.
- 4220-24P-4X—Switch Engine 32.7.1 and
later.
- 4220-48P-4X—Switch Engine 32.7.1 and
later.
- 4220-4MW-8P-4X—Switch Engine 32.7.1
and later.
- 4220-4MW-20P-4X—Switch Engine 32.7.1
and later.
- 4220-8MW-40P-4X—Switch Engine 32.7.1
and later.
PoE++
- ExtremeSwitching 5520-24W—ExtremeXOS 31.1 and later.
- ExtremeSwitching 5520-48W—ExtremeXOS 31.1 and later.
- ExtremeSwitching 5520-12MW-36W—ExtremeXOS 31.1 and later.
- ExtremeSwitching 5420F-8W-16P-4XE—ExtremeXOS 31.3 and later.
- ExtremeSwitching 5420F-16MW-32P-4XE—ExtremeXOS 31.3 and later.
- ExtremeSwitching 5420F-16W-32P-4XE—ExtremeXOS 31.3 and later.
- ExtremeSwitching 5420M-24W-4YE—ExtremeXOS 31.3 and later.
- ExtremeSwitching 5420M-16MW-32P-4YE—ExtremeXOS 31.3 and later.
- ExtremeSwitching 5420M-48W-4YE—ExtremeXOS 31.3 and later.
- ExtremeSwitching 5720-24MW—Switch Engine 32.1 and later.
- ExtremeSwitching 5720-24MXW—Switch Engine 32.1 and later.
- ExtremeSwitching 5720-48MW—Switch Engine 32.1 and later.
- ExtremeSwitching 5720-48MXW—Switch Engine 32.1 and later.
- 4120-24MW-4Y—Switch Engine 32.7 1 and
later.
- 4120-48MW-4Y—Switch Engine 32.7 1 and
later.
- 4220-4MW-8P-4X—Switch Engine 32.7 1 and
later.
- 4220-4MW-20P-4X—Switch Engine 32.7 1 and
later.
- 4220-8MW-40P-4X—Switch Engine 32.7 1 and
later.
